You can use Hardy on wooden floors,
You can't use Hardy on concrete.
The primary function of HardieBacker cement backerboard is to provide a water resistant flat surface to tile on; it is not designed for use over concrete. The minimum sub-floor specified is 15.8 mm exterior grade plywood sub-flooring with a deflection not greater than 3mm for live and dead loads over joists that do not exceed a span of 400 mm centres.
You can't dot & dab Hardy.
No. HardieBacker cement board is not suited to this type of fixing application.
Both answers taken jameshardy.co.uk website.
Having seen quite a few other vids on Hardy Board
You might be about the video. There seems to be a few other products similar to hardy on the market, it possible could be one of them?
Well,I ain't gonna argue with a man who googles every bloody thing
I don't just use hardi,I ain't bothered either way,carry on son
