6mm ply is no good. What's currently down there. Boards? Chip? Old tlles etc
Chip and 9mm ply ontop.. Too thin/weak?
As above Hagar. But you need to sort out any defection first. Then as Bri says, glue and screw hardiebacker over the top.
I need to SLC the chipboard then GLUE and screw the hardie down?
I guess that means I will have to SLC twice... once on the chip board and once on the hardie.
You don't need to SLC the chipboard, just make sure there is no deflection before you glue (with tile adhesive) and screw the HB.
