Discuss 20mm exterior porcelain cutting in the Canada Tile Advice area at TilersForums.com.
Concrete guy
It would be solely to take place of a 1200 bench saw for stone and 20mm porcelain.
It's ideal for that, we used to cut up 30mm thick granite slabs with one using two 1600mm rails and a coupling.
A good set up is the saw, 1x 800mm rail 1 x 1600mm rail plus a coupler. That gives you 800mm, 1600mm & 2400mm cutting capabilities in one tool.
Despite coming with a 170mm blade, it will take a 180mm blade without any snagging which opens up the options tremendously.
peteablard
1,058
Cheshire
As Alan mentioned it's only really suitable for outdoor use due to the water feed running everywhere. That said some sort of tray system could be set up to catch the water but would need constant emptying. I only really need this for new builds I do for a builder where making a mess outside isn't a problem
Reply to 20mm exterior porcelain cutting in the Canada Tile Advice area at TilersForums.com
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
What is best way to lay outside 20mm Porcelain patio, Would I compact soil, add hardcore and...
Hi everyone Looking soon at retiling a shower enclosure walls at a local leisure centre. Once...
Lakey
Crawley
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
