I started some repair work on New Years Eve. Water had been getting behind some tiles and the tiles were coming away from the wall. I removed 3 tiles 600x300. The fourth tile could not be removed because it would have definitely broken in half. The tiles are about 5 years old and the customer has no spares. The layer of plaster behind the tiles was absolutely soaked and came away quite easily. The second layer of plaster had blown and came away too. I am now down to the brick wall. The gap between the brick and the back of the tile is 22mm. Could I just use rapidset to build up/pack out the gap. The previous tiler did not Silicon the internal corner, the grout cracked and the spray from the shower poured into crack between the tiles. I had hoped for 2 visits to mend this problem. It now looks like I’ll be making 3 trips! Cheers Sean
