Discuss 400x300mm tile 10mm thick on plastered wall? in the British & UK Tiling Forum area at TilersForums.com.
U
Unregistered
I have purchased some tiles 10mm thick (400x300mm ceramic). The window wall and main bath wall are plaster. the overbath shower wall is plasterboard. Will this be okay or am i taking a chance on the plaster wall? If okay what primer and adhesive and grout could anyone recommend? Any help would be much appreciated.
doug boardley
use any good make of primer on the plastered wall,make sure the plaster has cured for 6-8 weeks!
depends what plastered substrate is David, gypsum based basecoat and skim I agree. Plasterboard and skim considerably less imo. But still think "unregistered" is exceeding safe weight limits.:builder2:
Reply to 400x300mm tile 10mm thick on plastered wall? in the British & UK Tiling Forum area at TilersForums.com
Some helpful advice/opinion would be appreciated... Existing tiles on walls, some of the walls...
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
