Discuss 600 x 600 marble tile joints in the British & UK Tiling Forum area at TilersForums.com.
Matt i have an account at chester and getting good rates on the kerraquick at the moment but no go on the maxi
Jaluka – ref your cracks in the doorway, for future ref on UFH, where you have lots of your heating pipes running together (near manifold or going thro gaps) or you go through the doorway (you have two slab of screed effectively necking down together ) then you can put light square wire mesh (about 100mm squares) over the pipes to act as reinforcement to help eliminate cracking, the UFH firm I use actually shows where to insert it on the layout drawings. In fact we anchored the pipes on top of 250 square mesh throughout with the 100 mesh added on top just through doorways and at the manifold junction (also on top of Celotex and with fibre mix in the screed) I have a real doubt that it was your builder (was he a proper screeder?) putting a trowel across a doorway … in fact that sounds like total bs to me! (I tell you there is more bs in building than in farming … and that trowel comment really smelt of cow).
Are you flooring the same tile pattern between the rooms? If not you could insert a tile area to tile area threshold (Gemini) across the doorway, this will finish off each door in any case (by providing an aluminium threshold exactly under the door closed position) and effectively gives you a 10mm expansion gap hidden under the press-on ali plate? If you are flooding the tiling throughout the rooms without threshold then you have no choice but install and rely on the decoupling mat together with using the stress relive the screed ideas from Ajax.
… Stan
1. it fails to meet the relevent British Standard code of practice. Also there is still the risk that a crack could occur later on once the coverings are down.
2. I think it is better wherever possible to place a proper joint former to prevent the restraint in the door way of as you rightly describe two separate slabs necking down at the same point. Obviously this means a joint in the tile face as well.
sorry again Ajax
i guess you refer to the Dil EZ, it seems to penetrate right down thro the screed, and that i have not looked at before - so thanks for that. Stan
Negative Stan. The EZ is for putting stress joints into the tile face itself. The DFP is between 60mm and 100mm deep. The self adhesive strip on the bottom is designed to stick down the the slip membrane which goes under the screed or insulation. You then screed up to either side of the DFP strip so that you have a full depth compressible isolation strip in the screed. I actually use the springvale version which is blue but can't find a pic of that on line.
Reply to 600 x 600 marble tile joints in the British & UK Tiling Forum area at TilersForums.com
