Hi,
Is the bitumen an adhesive residue left behind after removing vinyl tiles such as marley etc, or is it a flooring grade asphalt? Flooring grade asphalt can be tiled with basic prep work.
Although there are levelling compounds available that are specified as suitable for laying over bitumen residues prior to tiling, it would be much better practice to try and mechanically remove as much of the bitumen as possible to avoid the potential failures associated with it, prior to using one of the levellers.
What tends to occur is that as the cement based adhesive cures over time and increasing its bond strength, it pulls of the bitumen layer which is weaker than that bond. To this end remove as much as possible, so there is more contact with the substrate underneath the bitumen. With tiles of that size/type you will most like have to use a thicker bed of adhesive, so make sure it is a low shrinkage product or suitable for the thicknesses required as the
standard cement based adhesives tend to shrink and pull bitumen off easier.
This is all based on the floor being a solid screed/concrete etc.
