Discuss 6mm insulation board under hardierbacker for UFH? in the Canada Tile Advice area at TilersForums.com.
Hi - This is my first post so i should start by saying thanks for all the info i have got from this site in the past years.
I have bought electric UFH mats along with 6mm insulation boards.
I am looking to tile my 4m bathroom floor which has t&g wooden floor. I will screw this down but looking for advice on how to build up the layers to the tiles.
I was thinking Flexible tile adhesive to bed insulation boards then tile adhesive again to bed 6mm hardiebacker board and screw threw both into the floorboards.
Then attache the UFH mat to the HBB and layer more flexible tile adhesive to tile on top.
I don't want to build up the height and trying to avoid pulling up all the existing floorboards to replace with ply.
will this be a suitable build up for floorboards/ UFH and tiles
Cheers
Thanks for the heads up - but i have already bought 6mm insulation can i just use this instead of the suggested 10/12mm? - i am using ceramic 300x300 tiles.
As hardiebacker has no thermal properties i would presumed i would need the 6mm insulation in the build up somewhere, hardiebacker or not.
Reply to 6mm insulation board under hardierbacker for UFH? in the Canada Tile Advice area at TilersForums.com
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Hi all, Will I be setting myself up to fail if I use the Dunlop CF-03 Flexible Fast Set Tile...
bristol
    Votes: 5 4.5%
    Votes: 8 7.1%
    Votes: 7 6.3%
    Votes: 32 28.6%
    Votes: 14 12.5%
    Votes: 29 25.9%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.0%
    Votes: 18 16.1%
    Votes: 13 11.6%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
