Discuss 6mm Marmox on Walls in the UK Tiling Forum area at TilersForums.com.
siremastimus
I have just had my bathroom plastered with bonding on the walls to make them more even in preperation fixing Marmox backer boards. I am planning on fitting 10mm on walls, priming the wall first with BAL SBR (mixed in 2:1 Ratio), then fixing the boards on a bed of mapei keraquick, allowing the adhesive to dry before finally securing with screws. On one wall however where the door is, by the time I add the 10mm for the Marmox boards and the tiles the wall will be near enough flush with the door surround which isn't ideal. Could I use 6mm board on this wall as its well away from the bath and shower? If 6mm is OK would people recommend that I still screw them in or is a bed of adhesive all across the board enough? Tiles arent too large at 380mm x 250mm and wall is quite small?
As always your feedback for a DIYer is greatly appreciated!
Reply to 6mm Marmox on Walls in the UK Tiling Forum area at TilersForums.com
    • Friendly
I'm having a nightmare trying to establish product info from distributors. For example...
6mm Marmox on Walls
    Votes: 6 4.6%
    Votes: 11 8.5%
    Votes: 8 6.2%
    Votes: 37 28.5%
    Votes: 16 12.3%
    Votes: 31 23.8%
    Votes: 3 2.3%
    Votes: 2 1.5%
    Votes: 19 14.6%
    Votes: 18 13.8%
    Votes: 15 11.5%
    Votes: 7 5.4%
    Votes: 3 2.3%
    Votes: 2 1.5%
