DHTiling
Hi all,
Which is the best Tile adhesive to get?? i've have a concrete floor with a 6mm ply base which ive used evo to stick it down with. I've got warm-up underfloor cable to go onto this and was wondering which is the best tile adhesive or grout to buy??
thats all
Hello and welcome....
6mm ply isn't really suitable for tiling to...it is moisture un-stable and can swell even from the moisture in your adhesive...
But i am also concerned with the way it is stuck down...you would normally screw and plug it and if that glue breaks down then nothing is holding it...and then you are adding a heating element to it, can the glue withstand thermal expansion and contraction..?
You only want to do this job once, so think carefully before you go ahead on that ply...
