ollymonkeynuts
Hi, Over the main bathroom floor im using 18mm WBP over joists with added noggins. On top of that will be 10mm Marmox board on a 2mm addy bed. Total 30mm.
The shower tray is a AKW tuff form tray (22mm). I wasnt going to put UFH over this tray just over the rest of the floor but looking at the levels if I was to put 6 or 8mm ply under the tray it would bring it in line with the rest of the floor. Then I could UFH and SLC over the whole floor.
If this ply is correctly primed (under & edges) would it be OK?
The other options are a) is not to have UFH over the tray, just to lay 18mm ply over all of the floor, put the tray onto this, then elsewhere 2mm addy, 12mm Marmox, 3mm UFH under 4-5mm SLC.
b) lay the tray direct to the joists then dont use Marmox just lay the UFH onto the ply and 1mm SLC to get it to the tray level.
Which would you do? Thanks.
