Discuss 70m2 floating chipboard floor in the Australia Tiling Forum area at TilersForums.com.
what a great tip mate thanksPS I always thought that the no-more-ply sheets were a gimmick but after lengthy conversations with Nicobonds techy department i decided to give it a go and it is a very good product, slightly awkward to use cos they have the peel off backs to them but once they are stuck down they are really stuck down!! Little tip, set your floor out as your going to tile it then stick down your sheets so the edges run in line with your chalk line then just simply use the edge of the sheet as your line to follow.
Could you elaborate on the construction of this 'floating' floor, what size tiles and weight you'd expect it to take/add to the structure?Hi would you or won't you tile onto a 70m2 floating chipboard floor ??? I'm a no but customer really wants it tiled ?
5m3 of ready mix and I know a guy who would put that down in a good morning....
Lifting the floor, shifting it,skiping it,cleaning it, sealing it, then laying it, come on whitebeam even you know its not just bloody dumping it and layinig it on a job like this, jesus, what is it jyst gonna be £800 ? Ffs
Reply to 70m2 floating chipboard floor in the Australia Tiling Forum area at TilersForums.com
