Discuss 70m2 Floor, 2 substrates, Ditra and Hardie? in the Canada Tile Advice area at TilersForums.com.
clipboard2008
The underfloor heating is already installed by the builder between the joists. It is set in a tray which is then filled with screed to transfer heat. It's quite popular as it allows you to put underfloor heating on second floors. This is obviously a ground floor.
Certainly can't fill underneath the caber flooring.
My plan is to hardie backer the floor then ditra matt it. I know it's a costly option but it's the only way I can see of ensure it's stable enough so it doesn't crack?
Dumbo
I wonder how many builders get structural engineers calculations on that before loading the joists up with screed
Spare Tool
The problem you've got here is no...or should I say not many ;) tilers on here will give you advise to just uncouple and tile over two substrates without following the joint directly through into the tiles, had this dilemma with customers before and tiles have cracked (I told em so :)) then again some haven't.
I've used Silicon to adhere tiles across a joint before on a job that had cracked to remedy and it worked , used marmox boards plus a crackmatt only this year as a customer didn't want a dodgy shaped concrete to wood expansion joint in her floor and up to now its been fine, there is no defining answer, you won't get any guarantees off anyone unless you do it by the book, otherwise its a gamble and I'm afraid your stuck between a rock and a hard place with this one.
Bond
528
Highland
If there is access and enough space in the sub-floor area, you could add beams or other support to the floor joists.
Reply to 70m2 Floor, 2 substrates, Ditra and Hardie? in the Canada Tile Advice area at TilersForums.com
I'm embarking on tiling a kitchen, wall-to-wall (under washing machine etc). most of the floor...
Hi, I have 40m2 of extension joined onto about 30m2 of the existing house that I want to tile...
Afternoon all, I am putting together a some idealised cross-section sketches to plan out...
Hi Ive been browsing your forums over the years looking for guidance for odd tiling DIY tasks...
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
