Discuss A big hole in the Canada Tile Advice area at TilersForums.com.
E
edie
Greetings.
This is my first post here so go easy please.
I have a hole to fill in a shower room, the picture shows it well.
I was thinking of taking the four tiles out that surround the hole and putting a piece of board or MDF in the gap and then tiling onto this piece of board.
I can use a slightly oversize piece of board cut into two halves so I can insert them into the hole and then was thinking of glueing the new board onto the back of the old board using gripfill ( I hope this makes sense).
Then I was thinking of simply grouting new tiles onto the MDF.
My question is does this sound like a good plan and also would grout adhere OK to MDF or would I need to put a layer of some sort of bonding onto the MDF first?
I also have to tile from the top of the shower unit up to the ceiling, it's only about one foot but it has been painted so again I am not sure if the grout will take to the paint.
I would really appreciate any opinions here.
Thanks very much.
P.S. This is not my shower and the existing tiles have been put onto plasterboard.
I put a supply in for an electric shower and the guy has asked me to patch up this hole.
I'm thinking if I patch up this hole I might be held responsible for the rest of the shower if it leaks.
Maybe it's best to walk away, what do you think?
E
edie
Well the electrical supply and the shower have been installed which is was I was asked to do.
I ran the mains 15mm water pipe and the electrical supply down behind the tiles in the stud wall that you see pictured.
I drilled two holes into the tiles and pulled the cable and the mains pipe out then terminated them into the electric shower.
The two holes that I have made to fit the water pipe and the cables can be sealed easily enough with Silicon and there are no leaks in the joints that I have made to the 15mm mains water pipe.
I didn't really want to touch the water supply but seeing as I was in the loft and installing the electrics I agreed too.
Can anyone see anything wrong with what I have done EG feeding the water supply down behind the tiles in the stud wall and then cutting a hole into the tiles to retrieve it?
The shower is in a house that has been bought by a landlord.
The house was owned by a keen DIY'er and this shower room is I suspect a result of his DIY antics.
The real problem is the house is now a shared house with five people living in it and that shower room will have a lot of people coming and going.
It will be used an awful lot.
Reply to A big hole in the Canada Tile Advice area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
A big hole
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
