I
Ian
Evening all, all the people with the relevant knowledge are in here so I won't post in the open forums, otherwise I might end up with conflicting information. Right, been to look at a church floor this evening, it's had some pews and the wooden boards they sat on removed. It has left a lime sub base that is on the whole quite solid with a few loose areas. The church is grade 1 listed and English Heritage have said that the new screed must be lime and no concrete products are to be used, there is no DPC currently and one can not be added. So my questions are,
What is the best way of prepping the current base to accept a new screed (approx 50mm)?
What should the screed be constructed from?
How long before this is tileable?
What adhesives/grouts should be used?
I may be able to get away with a layer of SLC on top of the lime if necessary, will this bond?
Any information that you think may help will be greatly received, I've attached a picture if it helps. Thanks in advance.
