Guest viewing is limited
Discuss A hopeless DIY needs help in the British & UK Tiling Forum area at TilersForums.com.
A1P
Hi.Sorry to hear about the builder.You have had lots of good advice re-the tiling.Can I just advise you to pursue your builder if there is other work to complete or any of the work done is not upto standard.Trading standards will advise you and hopefully also have a list of dodgy tradesmen to add his name to.There are procedures to go thru and they will help you.It will take up your valuable time but is worth doing depending on the size of the problem.You really should have some details of what he has actually done and he should offer some sort of guarantee.If just the tiles possibly not worth the hassle.
H
hopeless
Hi thanks for your advise.......A friend recommended this chap as he worked for her husband who is a builder however, I later found out this chap also has a short fuse when I questioned him about something that wasn't right. He responded to me quite aggressively so I walk away as I did not want to go there. Later I found a few items broken, my shed lock was sheared off, my car pump which was left in the shed had the rubber tube cut off. Like many cowboys he said he would come over to finish the work but did not turn up for week. It got to the point that I just wish the work would finish quickly as his attitude got worse. I do fear that if I complain I may end up with broken windows or worse still slashed tires so naturally I would want to see him again even to put things right. Thank you for your response....Hopeless
A1P
What a nasty situation to be in.You are the person who has been let down and left with less than satisfactory work and possible,but hopefully not,future problems.It is wrong that you should feel intimidated but I can quite understand that with no support you do not feel like taking him on.At the risk of sounding like an 'agony uncle',perhaps you could get your friend's hubby {the builder)to have a look tho'that might spoil a friendship.Best wishes.
H
hopeless
Thanks for your kind words. :20: I think I may have to resign into cutting my losses and chalk this whole chapter to "never employ a builder who has anger managements issues". However looking on the bright side people on this site like you and many others have been very supportive, I am very grateful for that.
Best wishes.........Hopeless
Reply to A hopeless DIY needs help in the British & UK Tiling Forum area at TilersForums.com
Hi, I recently purchased my first property and the existing kitchen floor porcelain tiles were...
benchwarmer
Thanks for taking your time to read through this and really appreciate the support! So me and...
I'm looking at laying some large ceramic tiles, on top of Arditex NA SLC in my front porch...
Hi Guys I have a tiled kitchen floor that needs replacing to address the hollow and hence mega...
Deleted member 49260
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
