cam_low
Eventually got this floor up, what swine it's been thanks to 'fabio'. I can't go into how much I want to cut his fingers off.
Anywho the floor is overplyed, 9mm, and ufh stuck to this then ditra the and inch of SPF and then tiled.
This is the current state of play. The white is a mix of SPF and fluff from the ditra. The two Blue patches are primer in a dilute and straight state. They appear solid enough and both have enough key to take the SPF for the ins boards the ufh, slc, tile.
Would this be your method to continue fixing ?
