Discuss A question for AJAX. in the Canada Tile Advice area at TilersForums.com.
The Legend; Phil Hobson RIP
Hi folks, this one is one for anyone, but Ajax is the one I hope can help me.
A couple of floors I am pricing are on the same new housing development. The substrate looked to me like Anhydrite, I asked the question as Alan always tells us to do. But after attending the exellent course in Durham that was hosted by Ajax. I still am not sure what this is, I have managed to get some info from the builders, I think it is probably sand and cement, but would like some advice.
The only info I have had is the subsrate is 75mm c35 fibre mix 10mm aggregate. If anyone could shed some light on this for me I would be very grateful.
Cheers, Phil.
Gazzer
It sounds like a standard sand and cement to me ..with fibres of course.
Identifying Anhydrite screeds becomes easier after the first, if it looks smooth, light grey and looks as if its leveller it stands a good chance.
I have had same issues when asking for details on screed though,..... "screed is screed innit ?"
Cheers Neale, this one has me baffled, it is pale grey and very smooth, but not as flat as you would expect from Gyvlon or the like. The builder has only given me the c35 fibre mix 10mm aggregate, which I presumed would be S&C. But I need to be sure before pricing. Cheers.
Ajax123
1,213
Lincolnshire
Cheers, Phil.
That sounds like it is probably an agilia type concrete floor which is cementitious. When finished it looks remarkably like anhydrite. It actually caught me out once on a job in Leeds beleive it or not. There are often cracks in agility screeds particularly if there are no joints but not always...
The one thing I did notice about the Gyvlon I'm going to tile.
No expansions across doors,
This is a good give away. 
I asked a week or so ago about identifying a calcium screed but got no replies..
That is what is frustrating me Stef, even the builder don't seem to know.
Ajax123
1,213
Lincolnshire
I can say for certainty that if it has 10mm aggregate and fibres in it is not anhydrite.
Ajax123
1,213
Lincolnshire
I would still press them for details, they should have an invoice or details for site. If not get screeders name and call him, thats what i have to do.
I agree. However It might not be a screeder but a ground worker depending on when it went in. Ths can be a good indicator...if it went in before the main build it is unlikely to be anhydrite. A few give away signs. 10mm aggregate, fibres (these are really fine so you have to look carefully) presence of a waxy curing agent on the surface, method of installation (normally anhydrite goes through a trailer pump where concrete us normally through a concrete pump or by direct discharge). Depth is obviously not a reliable indicator nor is colour. Presence of steel reinforcement is a good indicator as well...
Chemical tests are possible but they are a health and safety issue as they involve the use of acids.
DHTiling
I was edging on agilia , hence asking about joints as they are normally inserted at 3 mtr intervals.
But I will say an agilia screed is deffo identifiable over anhydrite or shall I say the ones I have tiled have been.
But as mentioned , always double check and if bit is agilia then the curing agents are now in the mix , instead of sprayed on afterwards.
Reply to A question for AJAX. in the Canada Tile Advice area at TilersForums.com
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
Evening Guys, You have probably seen many posts like this coming...
Good evening to all. I’m here this evening looking for some advice if you would be so kind...
Hi all, New here although have been following the odd thread or two on and off. I have a...
Waluigi
K
hi anyone give me some info on the dural decoupler or tile master matting , question re dural...
5K
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
