Discuss A Tricky One A Second Opinion Required in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
Rossymcg
Got a kitchen/
dining room to do with a loveley red/white/green/pink marble, it 4 meters wide and 7 meters long with eufh. Simple so far.
However one part of the floor the 1st 3.5 meters in length is a suspended concrete floor, rock solid no deflection, 2nd half suspended timber floor also solid no deflection,
Concrete floor has black vinel tile adhesive residue, suspended timber floor has been re laid almost perfectly level with insulation under 18mm marine ply, nogged out, ply is clean as it was left off till after plasterer had been, and ply sits 25mm higher than concrete floor,(concrete floor runs out of level by 25mm and I intend using 20mm insulated backer board and SLC the 5mm back too level,
So how would you go about it?
Slurry the black adhesive or scrape it off?
Put a soft expansion joint at the point of the two different substrates,
1 ufh mat or 2? 1 over each substrate? I won't be putting any insulated backer boards over ply as 100mm kingspan sits below ply, would you put a slip mat between the ply and stone?
Ufh will be 150w I don't think I need to decouple that from the marble tiles, what do you guys think?
Cheers
Remove as much 'black' as u can, and use TM's prime+grip on floor.
Expansion between two substrates.
Insulation boards glued and screwed with Wedi washers.
Latex concrete to level.
Two substrates, two UFH mats, two controllers.
SLC over mats, and decouple each side individually.
Always decouple stone from heating.
Set floor with joint along expansion joint in substrate.
And soft joint between two floors if they won't have proper expansion joint.
Got a kitchen/
Cheers
3_fall got it spot on ... The only diff I would do is Mapei Eco prim grip with utraplan renovation and ditra heat tb to heat and uncouple. Always use expansion with change of substrate
Reply to A Tricky One A Second Opinion Required in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
I'm a total tiling beginner having my kitchen/diner redone by builders. The dining area has a...
Hi, a long time since I have been here but back for some advice/reassurance ! About to tile my...
Hello we are currently trying to choose a tile to lay on the ground floor (70m2) of our house...
Tile Buying Popular Threads
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
