Discuss Adding Bal GT1 to Mapei Ultracolour Plus Anthracite ? in the UK Tiling Forum area at TilersForums.com.
Tony Cooper
Hi Lads,
Anyone had any problems adding Bal GT1 Admix to Mapei grout ?
Got a job next week labour only, customer bought all the gear from Tile Giant, 5m2 of mosaics for a kitchen splashback then 15m2 of 600 x 300 Jakarta polished porcelain on the floor. Mapei ultracolour plus anthracite grout for both.
Hate using Anthracite (it's a nightmare!) so wanted to try and make it a bit more pliable/flexible to use by adding the GT1 as I normally use Bal grout and never had any problems adding it. Just wanted to check that there'll be no issues with mixing a product by one manufacturer with another one, if you get my drift.
Also, fitted Jakarta 600 x 600 polished porcelain in the past and been told by Tile Giant they don't need sealing. But this customer has been told they do need sealing and sold them LTP sealer. What do you reckon ?
Cheers,
Tony
bugs183
Don't do it!!!!!!!
Never mix manufacturers adhesives etc, plus adding GT! is going to make any dark grout a piggin nightmare.
Mapei grout is not as bad as people make out, add the specified amount of water to the bag, mechanically mix, it will seem really stiff.
Leave for a few minutes then mix again, the polymers willl slacken in the grout and it will be easier to use.
Reply to Adding Bal GT1 to Mapei Ultracolour Plus Anthracite ? in the UK Tiling Forum area at TilersForums.com
  • Locked
If there is a make you use a lot and it's not listed , then mention it and it can be added for...
40K
K
Hello, I have just grouted my new tiles and after 3 days it has started to go yellow in...
8K
E
So I'm having trouble with a customer relating to grout (Bal Micromax) I have tiled 70 sq...
2 3 4 5 6
16K
Hi I have just grouted my newly fitted ABK Reworks Multi Beige 600x300 Porcelain wall tiles...
23K
jazzhands
Be the Best with BAL! The importance of correct training should never be underestimated. As the...
8K
    Votes: 8 5.8%
    Votes: 13 9.5%
    Votes: 9 6.6%
    Votes: 39 28.5%
    Votes: 16 11.7%
    Votes: 34 24.8%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.6%
    Votes: 18 13.1%
    Votes: 15 10.9%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
