Pandemonium001
The Customer (wife) has requested a wet room down stairs.
house is new build so shower area stud partition walls have been reinforced, plaster replaced with green sheets, primed and tanked with mapie tape and WPS kit.
The shower is over head high flow low pressure, Tiles she has bought are dry stacked Quartzine Mozaic backed with mesh with little or no gap to grout,thats the biggest problem, they will probably be sealed with LTP Mattstone.
Area is 5m/Sq vertical
Any recomendations?
initially i thought of BAL easy poxy, which is no longer available, Mapie Kera poxy is not flexible enough. Would BAL Max Flex Fibre be O.K,
Floor:
concrete base raised with 2"x2", 18mm chip, 10mm marine ply screwed 100x100 and glued.
will be tanked using Aquadry's membrane.
Tiles 600x600 porcelain approx 5.5m/sq
Recommendations? I thought Bal Fast Flex grouted with epoxy or Mapie Keraquick with latex grouted with epoxy.
The room will hardly be used and if it will mostly for just the bath.
My prefferred Brands are BAL and Mapie
Any advise is welcome, Thanks.
Any recomendations?
Floor:
