Discuss adhesive for granite wall tiles in the British & UK Tiling Forum area at TilersForums.com.
L
leeamtiling
Evening all
Looking for some advice. Got a probable job. Customer wants 45mm x 45mm granite tiles on the walls. Which adhesive is best to use ? Also, she has a mosaic border for the halfway point in the wall, is it best to tile up to and inc height of border, then continue the next day ? third and final query, will i encounter many issues trying to cut the tiles with a dry cutter or is it best to use a wet cutter ?
All advice will be greatly appreciated
cheers
Lee
ps - still learning the trade
L
leeamtiling
Hi.
What would you guys recommend ? To be honest my gut instinct was to give it a swerve as i had a feeling it could turn into a nightmare. The tiles are huge and they are at least 12mm thick. Would the customer need to get the walls sheeted with plaster board ? and if so what would be the min depth ? Also what would be best to prime the floor.
Thanks again
Lee
Daz
I'm sorry to say this Lee, but you need to follow your gut instinct.
Being totally honest with you, I think you will get yourself into so much difficulty that it could knock your confidence for your future tiling career.
The tiles are far too heavy for plastered walls and plasterboard is not strong enough either. Your best option would be to mechanically fix cement boards to the walls.
The floor will need serious preparation too prior to tiling.
My advice would be to try and find an experienced local tiler that is prepared to do the job and allow you to assist / learn from it.
And as per Sir Ramic, step away from the PVA, it has no place in tiling!
Good luck,
Daz
grumpygrouter
Thanks for the advice on this one. I will opt out of this one.Before i go, what is best to use to prime ply floors prior to tiling . Once again many thanks.
cheers
Lee
Priming ply depends on on the chosen adhesive. Some manufacturers recommend not priming the ply, some do. You will need to read the specs from your chosen manufacturer.
Reply to adhesive for granite wall tiles in the British & UK Tiling Forum area at TilersForums.com
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
