Discuss Adhesive for large format tiles in the British & UK Tiling Forum area at TilersForums.com.
clarke
I agree. depends on tile weight and material.
I use tub gear on ceramics up to 30x40 as long as i can use an 8mm trim, anything bigger and its powder every time.
Porcelain I use tub gear up to 20x20 and anything bigger its onto powder, (tub gear needs to be porcelain compatible, make sure you check!)
If youre not sure, powder is better, stronger and youre definately covered with any tile.
Good luck.
Reply to Adhesive for large format tiles in the British & UK Tiling Forum area at TilersForums.com
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
Looking to lay large format (900x900mm) thin (5.5mm) porcelain floor tiles onto a sand and...
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
