Discuss Adhesive not gone off - after 2 weeks in the Canada Tile Advice area at TilersForums.com.
bugs183
Hiya Bolton.
My post sounded a bit aggressive there, sorry about that, i didn't word it as i thought i had.
I meant to say lets find out how the job was approached, who said what exactly, as it's complicated between what you wanted to be done, what the tiler wanted to do, but did, and what the Tile shop said or advised.
The thickness of ply does make and awful difference, with tilers here wanting around 18mm or above to tile on, as it is quite an unstable material to tile on to. The fact that the floor hadn't failed before is really down to luck, these floors are notorious for failing.
It's going to be an awkward one here as there are many factors here that each party can blame.
You shouldn't tile floating floors, regardless of how much ply you use, so the tiler shouldn't have done it, and Topps will say their adhesive isn't suitable for this situation, so i guess they will just say the adhesive failure is down to the floating floor, and incorrect thickness of ply.
Unless you have evidence that they actually said that this adhesive would work in this situation i can't see them paying up.
The tiler even though he was unhappy at the board thickness should have said no, but he took the job on and by that accepted responcibility for his work.
John Benton
1,138
Leeds
I was asked to install 30m of £100 per m porcelain tiles with electric UFH on a floating floor. The customer wouldn't do anything with the floor after I told him it would have to come up before I would tile on it. I had to walk away. The kitchen had already been fitted to the floor ready to tile round. Found out later it had failed, surprised, nope. I would never go anywhere near a floor like this, destined for failure.
kilty55
1,113
edinburgh
based on the fact the adhesive is still soft i would first ask for it to be checked out as thats not right at all
you cant blame anyone as of yet imo
i also hope a better aproach of install is carried out 2nd time round for the sake of your job
are the tiles salavagable atm? if so that itself is good news
whats your thoughts on who should pay for it bolty
BOLTY
Hi
some of the tiles are salvagable and can be cleaned off albeit time consuming. Unsure who should pay topps because it was them that recommended it? palace - because their product is still soft? its the cost to rectify thats worrying me alot of the utility units have been siliconed in in places, potential damage to the kitchen when removing to retile.. what i am finding is that everyone blames everyone eg: ply thickness, no one really helps topps tiles customer service just sends me round in circles, palace drags their heels..(they have had the sample to test for 4 days now) meanwhile i have a half finished kitchen and a mess of a floor
kilty55
1,113
edinburgh
ok hi bolty....so you have tiled wall to wall then fitted the kitchen,its hard to advise without seeing it and i know this is not an ideal solution but is it possible to remove all visible tiles and cut them neat round the kitchen to save the kitchen coming out? or is this not possible
as for waiting for a response from the addy company i understand its probably pretty frustrating waiting for an answer from them
wait for palaces response first is my advice maybe a follow up phone call in the morning might push things along>?
BOLTY
hi - cutting around the tiles is one option i will put to them, followed up a phone call to palace but you can hear which way thats going they said it could be tilers fault..6mm ply etc etc so they will just cop out im sure but i have still asked them to investigate why the adhesive has not set. Incidently the tiler has found out a bathroom was done last week with same product but water based and the same has happened so could be a dodgy batch..the other tiler aint getting anywhere with palace either. :thumbsdown:
Alan M
i think you should get a real pro tiler around to inspect the floor.
they would know what might have caused it.
check all the usualls like ply thickness, floating floor,primer used, ply screw enough,addy thickness etc etc.
then at least you have that info on hand when the batton is handed around when they all try to blame every one else.
macten
1,158
Nottingham
Ultimately if the adhesive was in date, stored and mixed correctly and has failed to go off in 2 weeks then it surely must be a bad batch of adhesive.
A tiled floating floor full of deflection and destined to fail won't stop that type of adhesive setting.
Of course there are lots of reasons why a floor of that construction and prep would fail months down the line but the adhesive situation is the obvious one at the moment.
Reply to Adhesive not gone off - after 2 weeks in the Canada Tile Advice area at TilersForums.com
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
I have recently laid around 30msq of porcelain floor tiles in our kitchen. The tiles have been...
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
We had a wet room fitted by a large company. We have issues with a few large steps where the...
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
