alanb
Good afternoon,
I am looking for some advice please on which adhesive/grout to use for my bathroom which is now kitted out as a wetroom. The tiles for the floor and walls are as follows:
Floor:
A combination of 410 x 410mm format porcelain tiles and porcelain mosaic sheets of the same size.
Walls:
450 x 250mm ceramic tiles
305 x 305mm ceramic mosaic sheets
The tile suppliers recommend I should use PCI Nanolight particularly in the areas most likely to get wet but this is very expensive (£30 per 15kg) compared to the many standard single-part flexis around.
Does this product offer any particular advantages/benefits over any other products, is it the most suitable for this job, does any other product match it at a more reasonable price?
I guess the grout needs to also be flexible and waterproof.
Any advice would be greatly appreciated.
Thank you.
Floor:
Walls:
Thank you.
