Mark B
Hello,
I've recently joined the forum and have read through as many of the posts concerning tiling onto wood floors as I can find.
I have been asked to tile a 4,5m2 wooden bathroom floor with 450x450 porcelain tiles and electric UFH. I'm fitting a new bathroom suite and will be lifting the existing chipboard floor to re-plumb underneath.
My question is what's going to be the best solution to minimise any height difference after removing the eisting 7mm lamimate flooring?
Having read all the posts I can find and speaking to the tile shop there seems to be a number of options,
1. Overply with 18mm WBP fixed at 300mm centres (approx height difference from existing FFL = 25mm)
2. Overboard with 6mm no-more-ply (or similar) glued and screwed (approx height difference from existing FFL = 13mm)
However, as I'll be able to replace the existing flooring, if I replace the existing chipboard floor with 25mm WBP ply and install edditional noggins as required can I then tile straight onto the new 25mm WBP?
Regards
Mark
Regards
Mark
