Discuss Advice for Wetroom Floor in the Canada Tile Advice area at TilersForums.com.
Waste of money even the reps & manufactures state it’s not worth using insulation Boards on wooden floors only need them on concrete floors.
You won’t get a return on investment for years. The savings on a concrete floor, pay for the boards after 2 years. So what’s the stat for wood which is a good insulator in itself it’s gonna be more like 10 years
Which is why you don’t need to use them waste of time and cash
You could even just use a product like warmup dcm pro for speed and less height which would also require no screed and is self adhesive
SimpleSimon
Deffinately seal slate before grouting. What sort of slate is it? Tell me it’s not riven !
Thanks for the extra comments - still reading through them - the slate is polished / honed so is very flat and smooth (much smoother than roof slates). It was from fired earth so cost a fair bit but fortunately not too big an area!
Edit: I'll let you pros fight it out about discuss what's best, but a couple more things that might be helpful to know is that I've already bought the underfloor heating mat - the wires on it are about 3mm thick.
Also, I'm not too worried about some of the heat going downwards, since the room below is the kitchen, and I've put some mineral wool insulation between the joists to help muffle sound which will insulate a bit too. There will also be a heated towel rail in the bathroom so the UFH is really to just take the edge off the coldness of the slate.
Thanks again for all the comments!
Edit 2: It looks like the height of the floor might not be an issue, since I have to build it up enough to meet the shower tray (20mm) plus 18mm WPB ply to support the shower tray from beneath (I can't put the 18mm WPB ply between the joists since there's an air duct in the way, so I'll have to put it on top of them, then the tray on top).
Reply to Advice for Wetroom Floor in the Canada Tile Advice area at TilersForums.com
Hi, Can anyone please give me some advice. I have an old bathroom and I want to turn it into a...
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
Hi all, I'm an enthusiastic DIY'er (first time poster) who has been slowly chipping away at an...
I'm planning on tiling my porch, and the tiles and adhesive will take up around 13mm of height...
    Votes: 9 6.0%
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 2 1.3%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
