Alan
Hi All, I will be laying 9m2 of 600x300 rectified polished porcelain tiles in my bathroom. It will be over green chipboard and I know all the advice is against this but I have tiled over chipboard before and not had a problem. It is new chipboard, well screwed down at 5” centres with no bounce in the floor.
Question 1. Should I prime the floor with something like Mapei Primer G?
I plan to use Mapei Keraquick with Latex Plus (recommended by Mapei for laying on chipboard)
Question 2. What size and type of trowel. I have read lots on the subject and I am more confused than ever. I would think a 10-12mm square notched trowel on this size of tile, giving a 5-6mm bed. But there are many recommendations for round notched trowels on floor tiles as it gives better total coverage. The problem is it also says that whereas a square notched trowel will result in a bed half the depth of the notch, with a round notch trowel, the bed would only be a third of the depth of the notch, so 3mm for a 10mm notch. Surely this isn’t enough.
Question 3. Tile spacers. As these are rectified tiles, I plan on using a 2mm spacer, is this OK? I am planning to use Mapei Ultracolour Plus which has a minimum grout line of 2mm.
