Advice needed re tiling job
Roddy
Hi
I have just had a bathroom re done and the bathroom done. Job took 4 weeks instead of the agreed 2 weeks.
I’m not happy with the tiling and wanted to get an expert opinion.
Firstly the tiles are not straight on lots of them. (Edges sticking with shadows at night) and the grout is flaky, patchy, different depths and different shades of white throughout.
Would you accept this quality and release payment? If not what would your recommendation be?
Roddy
1CE84C5D-4CC5-4029-8395-BB7BCC32AF88.jpeg B0EB4ADA-3A5C-43C8-97BB-B9EAA8D90C3C.jpeg F528003E-E459-4162-8D07-0CBE6974C211.jpeg 120CCC10-9C3B-47C4-9790-8597125D4F5F.jpeg 4795463E-E44A-4969-9AF5-CECA9D1EDB8E.jpeg 63369C7D-72DB-49A7-87EE-A109CB34E06D.jpeg 5B88EC6A-5A75-458C-AB50-2BD50CAD0BBA.jpeg
The tiling looks shocking and you can see those lipped tiles your on about,but what's not helping matter is the shadow that is been cast by the downlight above your shower head.Yes I would definitely hold on to your cash until the tiling has been sorted out whilst also have that downlight moved somewhere other than above the showerhead.
Tiles look fine . See pic.
Update:
They came back today to do more grouting. Is it just me or is this a poor job?
If it were the tiles everyone would be lipped, there are areas that look ok..granted they are far and few between. Would more suspect it to be crap walls, no prep and maybe a blob or two on the back of each tile.. Any pictures of the prep?
The tiles do have a bit of a bow in them which will exasperate the lippage problem, particularly with half bond.
That said, the preparation doesn't appear too thorough.
Tiles slightly dip in each corner, so you would probably get a slight lip , but most are not slight lips.
They have tiled on ply on the window wall, I can’t see any primer on the old sand lime walls either, unless it was done after .
Bit ropey really
first thing i do is check the quality of the tiles they look a bit on the rubbish side to me and if you start with rubbish the job ends up rubbish. the saying cant make a silk purse with a pigs ear comes to mind
That looks horrendous, maybe there is a slight bow in the tile but still, looking at that I’d say they didn’t even bother checking the walls with a straight edge and just followed the walls with a 6mm serration ......lips everywhere, grouting is so rough, i would condemn that and not pay....( why should you have to pay for a mess like that!.)..rushed, poor workmanship imho......needs taking down and start from scratch with correct preparation and correct practice.....NOT GOOD!.....NOT GOOD AT ALL.......people doing shoddy work like this should be kicked out of this trade.....I see it all the time it’s shocking!......was it done by a Tiler or multitrader?
They are out there but I think they are few & far between from what I have seen over the years ......if this was carried out by someone that just does tiling for a living then sumthin is a miss......
I think in this day and age of PC we are not meant to blame Jack for all mistakes!
Multi traders have an important role to play in the interior installation of modern bathrooms and I’ve been impressed by the standard and knowledge of many tradesmen who take the responsibility of the whole job.
Taking 4 weeks this was not a rush job as suggested by @Mark W Smith and certainly the quality of tile has a lot to do with the resultant finish. However an experienced tiler would have confirmed the suitability of the materials prior to fixing and appropriate advice given. Also I’am surprised we are seeing finished pictures and it has not been ‘pulled’ from day 1.
Not sure what the connection is between the plumber and the tiler.
But surely the plumber could have seen something was amiss and held off from 2nd fixing. Then again!
Roddy,
Time's Ran Out,
Roddy,
Time's Ran Out,
