Discuss Advice needed urgently please - NMP, Backer boards, Ply, Ditra???? in the UK Tiling Forum area at TilersForums.com.
saf
Greetings all,
this is my first post so any help is appreciated.
i am having my bathroom tiled with marble tiles.
now there was me thinking that it would be relatively straight forward and id be able to get any ol' tiler in and he would be able to put them up.
i have started to look through the net to see what options are out there and i must admit i am very confused.
at present i have t&g boards on the floor, my walls have been prepped up using plasterboards and skim on partitions and sand cement/skim against the other walls.
now with regards to the floor i am really puzzled about what the best option would be to tile.
a) do i strip the old t&g floor and replace with ply?
b) apply no more ply over t&g boards and tile over that?
c) strip old t&g floor and replace with ply and use no more ply?
d) apply ply and ditra membrane?
e) any other option you can recommend??
the floor level is an issue and i dont want to unecessarily raise it if i can avoid it.
the real problem for me is that i am not an expert or even novice when it comes to these things, this is my first house (first time buyer), i have gone overboard with an expensive bathroom and intend on sticking with it for as long as it lasts.
please can somebody help and advise me what would be the best option for me.
p.s marble tiles are 10mm thick.
thanks in advance!!
jay
Greetings all,
thanks in advance!!
Marble is not something any ol tiler can lay and requires a fair bit of experience .because if its not done right it will cost a lot more to rectify
best advice would be send Dave a pm with your location and he might be able to get a qualified tiler in your area to contact you via pm
good luck
jay
and welcome to the forum
saf
good luck
jay
hi there
who is dave?? and how can i PM him?
Del W
1,113
Canterbury
Posted by Oli
Substrate weight ratings
A common question, how much weight can my wall support, here are the reccommended max weight ratings in KG / m2
Plaster Skim on Plaster Board........20KG
Skim and Set Plaster...................28KG
Plaster Board.............................32KG
Sand and Cement.......................40KG
Cement Backer Board..................55KG
Hardibacker Board.......................45KG
Lightweight Tile Backer Board........40KG
Glass Reinforced Cement Sheet.....50KG
Gypsum Fibre Board.....................40KG
Remeber to factor in the weight of the tile / m2 AND adhesive and grout
Grout.........2KG / m2
Adhesive....4KG / m2
Reply to Advice needed urgently please - NMP, Backer boards, Ply, Ditra???? in the UK Tiling Forum area at TilersForums.com
I'm about to tile my kitchen with 600mm x 600mm porcelain tiles. I am tiling onto a subfloor...
TF Group Please Join
