Been out to see a customer about a kitchen floor. Sub-floor is concrete (years old) on top of which is newly installed insulated chipboard (4'x2') sheets, fitted by builder, plugged and screwed only at each corner!!!! There is a bit of deflection in places. Customer wants Warm-Up 10mm insulation boards laying which I will fix. Then the heat mat, that he will fix (he's an electrician), I will then install SLC and then lay 800x800mm porcelain tiles. Area is approx. 24m2.
What are your thoughts on this? Have you guys tiled on to the same background before and has it been ok? Is it suitable for what needs to be done to complete the job or do you think this could be a point of failure in the future?
