Discuss Advice needed........ in the British & UK Tiling Forum area at TilersForums.com.
barney55
Hi
I am looking for some advice, as I have a cloakroom floor to tile (1.7m sq). the tiles to be laid are 300mm square ceramic. the floor is only half inch ply which will require some noggins to strengthen and then I was going to screw the exisiting ply at 150/200mm centre where the flloor joist allow. I have been reading about ditra matting and thought about using this in order to keep the finished floor level down and it seems to be highly reccommended for tiling on timber floors with slight movement? Is this best or should i use 6mm ply?
If I use ditra do I need to prime the exisiting ply floor before laying the ditra matting? What adhesives would be best for this flooring, i have been quoted a good price on nicobond rapidflex(green bag)? Finally what grout would anyone reccommend.
cheers
barney55
cheers wivers and dave.
the timber floor as it stands is made up of only half inch ply, which needs to be noggined to stop the movement and then screwed down. so if i was to lay a 6mm ply on this and screw that down to the exisiting half inch ply I should be okay as long as I use bal rapid flexi or fastflex? You don't rate this ditra matting or just think that its an overkill, although I do need to keep the finished floor level down and ditra would do that?
neither of you said anything about the nicobond rapid adhesive, is it not and good?
Reply to Advice needed........ in the British & UK Tiling Forum area at TilersForums.com
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
    Votes: 9 5.3%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.7%
    Votes: 21 12.3%
    Votes: 40 23.4%
    Votes: 4 2.3%
    Votes: 4 2.3%
    Votes: 24 14.0%
    Votes: 19 11.1%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
