Discuss Advice on a floor in the Australia Tiling Forum area at TilersForums.com.
mike1979
I'm currently working on a floor they have had a kitchen and dining room knocked into one the wall that was knocked down has the block showing between the two floors it's at the same level with a 3 inch gap both sides of the block where the polystyrene insulation was so I was thinking about filling the gaps with concrete and ditra matting the whole floor the floor is fairly flat no underfloor heating and porcelain tiles will be used I've only used ditra a few times and always used one part flex am I sucking the right boob
mike1979
It's concrete they knocked a wall down in two rooms to make it one and the blocks go down to the footings so they obviously poured the concrete floors last and they left a row of blocks in as it was floor level there was a three inch gap both sides of the block that I filled up with concret and was worried that it was a potential weak point
mike1979
Reply to Advice on a floor in the Australia Tiling Forum area at TilersForums.com
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
I have a small kitchen with a floor area of 265cm x 140cm with the door recess adding another 20...
Advice on a floor
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
