Discuss advice on adhesive for tiling in a shower area. in the UK Tiling Forum area at TilersForums.com.
geo147
hi i bought and used some everbuild aquaseal wetroom tanking kit. i dont have a wetroom, it is a normal shower tray with 3 walls lined with green gyproc. i have used the tanking tape to do the corners and used 2 coats of the liquid membrane.
what tile adhesive should i use now? does it now need a coat of sbr primer? im fitting 10mm granite tiles. ive heard about d1, s1 adhesive waterproof adhesive flexible adhesive, i dont know what it all means and would appreciate some advice.
thanks
White Room
can you explain the reasons for that choice so that i can understand the pros and cons ?
thanks
If it gets wet it won't break down like a tubbed/dispersion adhesive and if your tiles are over 300 x 300mm a cement based addy is required.
Just reread your post and you say your fixing 10mm granite tile, do you know the weight per m2.
Reply to advice on adhesive for tiling in a shower area. in the UK Tiling Forum area at TilersForums.com
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
    Votes: 6 4.5%
    Votes: 11 8.3%
    Votes: 8 6.0%
    Votes: 39 29.3%
    Votes: 16 12.0%
    Votes: 32 24.1%
    Votes: 3 2.3%
    Votes: 2 1.5%
    Votes: 19 14.3%
    Votes: 18 13.5%
    Votes: 15 11.3%
    Votes: 7 5.3%
    Votes: 3 2.3%
    Votes: 2 1.5%
