Advice On Bathroom Prep.
Cabnero
Hi guys I was hoping to get some advice on prepping my mum's bathroom for tiling. The floor is floorboards covered in vinyl tile but as there is going to be moving of pipework most of this had to come up so was going to replace it with 18mm wbp ply primed underneath and edges. Although only a small area wanted to use a leveling system out of curiosity. Floor tiles are 60 x 60 porcelain and wall tiles are 60 x 30. Wanted to match the grout lines on the floor and walls. Do the clips in the leveling systems act as spacers in which case I would need to use this for the walls also?
The walls are half tiled and half I think rendered with a very bubbly finish which had been painted. Almost like artex. I was going to dot and dab plaster board the tank. I was also curious about using 10mm marmox. Would this be OK. One of the walls is external. Are there any considerations for this.
Many thanks for your help
Thanks Andy that makes sense. Would you mind advising re garding my previous message. As a matter of course di you guys not tile directly onto ply. I have done this in the pay and not had problems but id rather be 100% rather than 95% . I have only done three courses but have tiled four bathrooms in the past and id ratger be sure. I hope you guys don't mind these questions just wanna get things right. Thanks again.
