jbwtaylor
Hi,
I'm after some advice on preparing the walls and floor of a bathroom for tiling. I want waterproof boards around the shower, and I'm currently going with Marmox. First question is on the stiffness of the Marmox boards: are 12.5mm boards really OK to go straight onto stud walls? There won't be any movement? Or should I put some backer board on first?
On to the floor, similar question really: I'm laying UFH so was going to go for Marmox again, for the insulation, and waterproofing as a bonus. Have solid 28mm floorboards. Question is: will 10mm Marmox straight onto floorboards (with tile adhesive + screws) be totally solid? I'm tempted to go with some 6mm Hardiebacker on top of the floorboards, then Marmox.. is this overkill?
Thanks in advance!
Thanks in advance!
