Guest viewing is limited
Discuss Advice on best trim to use?? in the Canada Tile Advice area at TilersForums.com.
K
Katia
Hi all,
Currently in the process of picking tiles for my new kitchen and was after some advice on the best trim to use. I've used the standard round profile homelux plastic stuff before in the bathroom but found it tricky to get a decent mitre for the joins, and I can't stand the plastic corner pieces they do (I took great pleasure in ripping them out the old kitchen - no way they're getting back in!!). I had considered not using any trim at all but not sure how I feel about having 'raw edges' on show as it looks a bit unfinished and un-professional. Having done a bit of research on here I see a lot of people use square edge trim and was hoping someone would be able to tell me of their experiences and what they would recommend?
Whichever option I go for it needs to be fairly straightforward and most importantly look good. My biggest concern is how it will look round the window recess with all the different corners and joins - if anyone's got any pictures of the finished product I'd be most grateful.
Thanks in advance for your help :thumbsup:
Time's Ran Out
There are a few option available if you don't want plastic trim. Schluter do a range of square edge metal trims, Homelux do chrome in various finishes, and you could mitre the tile edges where they meet!
A lot depends on the style/look you are after as certain trims can be modern and no trims can look rustic.
trevortine
This the idea your looking for?
AMtek
I normally put all my trims on before i start tiling, the way you would with your beads before plastering, it just always made sense to me. If you haven't cut trims before i would buy plenty and just start over if you cut them wrong rather than trying to make the best of a bad cut, you'll be glad you took your time and re did any bad cuts a week down the line after its all finished
Reply to Advice on best trim to use?? in the Canada Tile Advice area at TilersForums.com
Hi, new to forum and after some advice after a professional install. Just had kitchen...
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
    Votes: 6 4.5%
    Votes: 11 8.3%
    Votes: 8 6.1%
    Votes: 38 28.8%
    Votes: 16 12.1%
    Votes: 32 24.2%
    Votes: 3 2.3%
    Votes: 2 1.5%
    Votes: 19 14.4%
    Votes: 18 13.6%
    Votes: 15 11.4%
    Votes: 7 5.3%
    Votes: 3 2.3%
    Votes: 2 1.5%
