oogabooga
Another vote for removing the skirting. If applicable, run a razor knife along the join between the skirting and wall, before you pull it out, stops any wall paint coming off with the skirting and thereby creating more work for you.:smilewinkgrin:
For the angle grinder I'd suggest getting one of those wafer thin turbo blades. Far less vibration and they cut much faster and with minimal chipping (once you the hang of it).
Make sure your floor is flat, flat, flat before you start and back butter each tile with addy, using at minimum a 10 mm trowel...... oh and one more thing
.... good luck
.... good luck
