Guest viewing limit reached
Advice on cutting marble tiles
U
Unregistered
Hi all, is it absolutely essential to use a wet cutter on marble tiles (20mm thick) or could I get away with a good quality diamond blade on my grinder? I shan't have a vast amount of cuts, it's a small area, and as i'm on a correspondingly small price I'm reluctant to fork out for an expensive wet cutter that may never pay for itself. I guess I could hire one, but they're heavy, and the job is up several flights of stairs; also, there is nowhere in the flat to make a splash. Any help would be greatly appreciated. Cheers, Simon.
Better with a wet cutter but a grinder with suitable blade will do the job, albeit dustier, unless you hold a damp sponge against the wheel whilst cutting, if your in the trade or getting into it your going to need one so bite the bullet, get a budget one for now and build up when the jobs come in,register also, you'll get lots of help.
Even though you cant splash you will still have to cut out side all that dust going everywhere, get a good mask.
i use a grinder if its floor tiling wet cutter for the walls alot neater. suppose its what your use to
Sorry, can you explain how it makes a difference, surely neat is neat no matter whether it's floor or wall ????
Think he means that if a cut is going under a skirting board a grinder finish is suitable, whereas if the cut is on a visible wall then the wet saw will leave the neater edge.
Unregistered,
DHTiling,
Unregistered,
DHTiling,
