Discuss Advice on fireproof tile adhesive in the UK Tiling Forum area at TilersForums.com.
Well...
The stove has been on for about 6 hours now - the plaster behind it is not much more than comfortably warm. I can easily put my hand onto it and it just feels cosy. I guess around 28 - 32C.
The warmest part is around the place where the chimney pipe enters the wall, about 1200mm above the stove itself. Again, I can hold my hand on the wall and it's not uncomfortably hot. I'm going to put on a circular enameled steel 'rosette' to protect the plaster from over-heating.
Any particular brand of Primer G to get?
Thanks,
Neil
it's the proper stuff to prime your plaster with Neil, you should be able to get it where you get your keraquick from, don't use PVA:yikes:
Reply to Advice on fireproof tile adhesive in the UK Tiling Forum area at TilersForums.com
