K
Kyle1
Apologies if this has been covered but I could not find much info on aquapanel searching, plentiful on haribacker...
I am after some advice on fixing aquapanel to a chipboard substrate, what adhesive people recommend and what thickness of adhesive to use. The substrate is in good condition and is very sturdy, plan is to use Mapei Keraquick tile adhesive mixed with latex plus to give it a good bond to the chipboard then screw in place, tape and fill the joins with the same adhesive.
What thickness of adhesive is recommended? is it really necessary to use a trowel 2/3 the size of the board like you would for a floor tile? Trying to avoid having to large of a step between carpet and tile.
Are there any other adhesives that would work as well (c2/s1)?
Do you need to prime the chipboard prior to using the adhesive?
Any advice for fitting?
Appreciate any help first time using cement boards.
Thanks,
Kyle
Thanks,
Kyle
