thegwads
hi all
wanted a bit of advice on a floor i am quoting on. lovely big area on a new build, around 70 square metres.
piped underfloor heating, which was screeded over last week. apparantly the screed has fibres in it which make it flexible. Now, the heating will probably not be run before the initial tiling start date, which is 16th feb. I have recommended ditra matting to be laid, as i am positive there will be a certain amount of movement on the new floor while it firstly dries out properly, and secondly as the heat is turned on and then fluctates etc.
i have recently tiled a travertine floor with underfloor heating with which the customer declined the ditra mat. went back 3 weeks later to tile the bathroom walls, and a stress crack on the concrete floor had transferred itself through to the tiles above, and a crack was formed.
my questions are these:
is there a flexible screed in anyones experience that truly copes with the contraction and movement in a new heated floor?
is ditra matting the answer?
will standard flexible adhesive do the trick?
any opinions greatly valued
