Discuss Advice on marble tiling a shower enclosure, adhesive, sealer, primer, substrates etc. in the British & UK Tiling Forum area at TilersForums.com.
djahawes
Hi there,
I'm DIYing a shower cubicle.
Have Marble tiles, 600/300 and the shower cubicle is stud wall. In its previous use it has only been plasterboarded and skimmed although I have replaced one wall with Marine ply now.
I've read various threads on adhesive, primer vs PVA, sealers and most worryingly suitability of substrate.
So questions:
1. If my plasterboard walls are not up to taking the marble tiles would replacing these with marine ply as well be suitable -I've read about aqaupanels but I happen to have several sheets of ply available...
2. would ply board need a particular type of primer as opposed to PVA?
3. The tile shop warned me of adhesive soaking through the tiles and showing patches if I didnt seal them first... Presumably I have to seal all faces before fixing the tiles to the wall or will different adhesives prevent this happening?
4. I have some Lithofin sealer left over from the slate floor -is this a suitable sealer in a shower situation? I'm aware of other recommendations on products on this forum but as I have some Lithofin I may aswell use it up -its pricey stuff!
Any other general advice on stone tiling appreciated... I've done several bathrroms but not with this size tile or material before.
David
H
heavytrevy
Re: Advice on marble tiling a shower enclosure, adhesive, sealer, primer, substrates
Use aqua panel or cement sheeting and tank it, last thing u want is water damage , its expensive to repair.
Also you need the right adhesive for your marble, somebody here should recomend a brand thats available in your area.
Also seal marble after you have fixed them but before grouting , ur lithofin should be suitable.
Trev
djahawes
Ok, cheers everyone. I think I'm getting the picture now. Ply is easy enough to take down so I'm thinking aquapanel throughout, tanked and I think the mapei keraflex is the right adhesive, then seal before and after grouting.
Going out to investigate tanking products, any recommendations?
David
peckers
Hi there,
So questions:
I would remove plasterboard and ply, and replace with a tile backer board such as marmox or wedi or hardi backer etc.
I wouldnt use ply!
You will need to use a white single part flexible adhesive for these tiles such as mapei keraflex white. Be sure to clean dust from back of tile using a damp sponge, I would do them first and then when the backs are dry back skim the tiles with a skim of adhesive and apply the tiles to the adhesive that has been combed onto the walls. No need to seal before you install as long as you work clean, cleaning tile faces as you go removing adhesive from them! when they have dried you can then apply sealer when this has dried you can then grout. remove all grout haze before applying second coat of sealer to tiles and grout.
You need to check the sealer you have is suitable for the marble tile you have not all sealers are suitable for all tiles!!!! Some are not suitable for calcerous stone!!!!
Take your time work cleanly and allow tiles to dry before each process and you will be fine. A wet cutter will be needed to cut the tiles.
David
Hope this helps :thumbsup:
djahawes
Fantastic help, thanks. many things i hadnt thought of!
With marmox or wedi, is there still the need to tank like with aquapanel or hardie?
If yes, why would you select on of these more expensive products and still have to fork out and tank it? Are there other benefits to these boards which i'm missing here?
David
peckers
David
Marmox supply a waterproof tape which you use on the joints of the board which seals the joints or you can use a polyurethane sealant, this will waterproof the joints in the weyt areas, and in the dry areas you apply a scrim tape over the joints in a dry area. there is no need to tank the walls or floors in a domestic shower imo, I would do in a commercial shower such as swimming pools etc.
take a look for yourself all the info here. Construction board, heat insulation, underfloor heating UK - Marmox UK Ltd
not saying this is the product you should use it is up to you, there all good!:thumbsup:
Reply to Advice on marble tiling a shower enclosure, adhesive, sealer, primer, substrates etc. in the British & UK Tiling Forum area at TilersForums.com
Hey all, New to the forum so go easy ;) I've finished tiling my bathroom floor with honed...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
