Discuss Advice on removing old tiles? in the British & UK Tiling Forum area at TilersForums.com.
GazLC81
Hi,
I have a job to go and quote for in the next couple of days and need some advice.
It's only my second job and first job where I will have to remove old tiles before re-tiling. What is the likelihood that I won't need to plaster? I have never plastered before and don't know what to say to the customer with regards to it either.
What would you experienced tilers say/recommend?
Many Thanks
Gaz
DHTiling
soz gaz, pure pot luck as to wot damage will happen till you take the tiles off.
if the worst happens just tell customer that there is more damage than estimated and room will need to be made good,either have a go yourself or try and get a plasterer .
most times it is just a bit a the skim coat that comes off and this is easily rectified with some one coat plaster just take your time and have a go yourself will save you loads of pennys. dont forget to prime areas to be patched first.. hope this helps mate!!
Paul Sh
Hi Gaz, With regards to the damage done to the plaster i think there is a few factors, (a) How good a condition the plaster was in in the first place, (b) How well the exsisting tiles were fixed and so on, TBH I would fore warn the customer that it may need plastering, just say to them that there is a possibility that the walls may need re plastering and see what they say, don't tell them it will, and don't tell them it won't, in my opinion you simply can't tell until you start removing them.
WHOOPS Beaten to it.
V
Varley
As the guys have said above m8, no way to know how bad the walls are gonna be, sometimes there will be very little damage, other times half the bloody wall comes down, just advise customer of this and then the possible solutions. If you don't feel confident in making good then advise customer that if the walls are really bad they may have to get a plasterer before you can tile.
DHTiling
and make sure its a decent plasterer last one i had the walls were more bowed and outa line than before told customer to get him back and straighten em up , she did for no extra charge, plaster said he thought the tiler would be able to sortem out by packing in extra ady,
what a dipstick lol
hi laurami. have got a good plasterer for the durham areas if you want it i will pm it to you .dave!!!
GazLC81
Wow thanks for the response guys! I feel more confident now after reading your comments. I had it in mind to just tell the customer that it's not possible to tell how bad the walls will be until I have removed the tiles and that I may be able to tile on it straight away or if the damage is minimal I can do the repair (how much would I quote and how long should I leave it???) or if the damage is more severe a plasterer will have to be brought in. Does this sound ok? Sort of things you'd say?
Thanks again guys, don't know what I'd do with out this forum!
Gaz
DevonR
I think it's important to let the customer know all eventualities as said above. Otherwise, especially if you get a twisty customer you could end up with them accusing you of the damage.
Forewarned is forarmed as they say. At least then they can figure this into the budget of the job as well.
Being honest with clients is a thing I think we should all look to do. Most will be happy you take the time to explain and will feel your giving a little extra value instead of trying to rip them off. May just make the difference in you getting the job as well.
Reply to Advice on removing old tiles? in the British & UK Tiling Forum area at TilersForums.com
Hi am Vinny, i am new to this forum and looking for advice on some old tiles that need replacing
Hi, Soon to lay 500mm sq tiles onto screeded hall/kitchen floor 25m2. Hall floor has vinyl...
got an 80m2 porcelain job upcoming ....seagrass carpet currently down on top of foam backed...
Hi all am changing tiles in my kitchen ans expect to damage the walls removing tiles . Think the...
    Votes: 9 5.5%
    Votes: 17 10.3%
    Votes: 12 7.3%
    Votes: 46 27.9%
    Votes: 21 12.7%
    Votes: 39 23.6%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 5 3.0%
