Matthew77
Hi All
I'm needing some advice on cleaning back & resealing some terracotta tiles. My local tile shop has put my name forward to one of their customers to do the work. I've been told by the shop manager that the customer has all the right strippers & sealers supplied by LTP and all I need to do is clean back the terracotta and reseal it. Areas seemed a little vague but I'm told its around 10m² of floor.
I'm under the impression that there may be a bit more work involved in this than just stripping the sealer/oil/beeswax back & re-sealing it all. from what I've read terracotta needs between 9 & 12 coats of sealer?
Also if more than one coat of Stripper/sealer/oil/beeswax is needed how long should a job like this take with drying times between stripping & sealer coats take roughly?
Tool wise do I need any specialist tools or brushes to clean the tiles and the sealer off?
Matt
Matt
