Discuss Advice on tile size and materials. in the DIY Tiling Forum area at TilersForums.com.
tfasb21
DIY Tiler
lu5 5ue
Hello.
After some general advice for a DIYer for tiling a shower alcove.
Height is 2100mm to ceiling
Two side walls = 900mm width each.
Back wall = 780mm width
All stud walls.
Fixed to Stud walls is Wickes STS Tile Backing board (10mm thickness),
Best tile size and thickness to use ?
Is ceramic easiest tile to cut to size ?
Best general tile adhesive to use ?
Best general grout to use ?
Many thanks.
Boggs
1,118
Uk
Hi, welcome to the forum. :)
Just a quick check, have you used the round/square washers when fixing your boards to the studs?
Also you will need to tape and tank over the joints and screws to make the area fully waterproof. :)
Tile size is really a personal preference, but I would be inclined to use a 600 x 300 myself.
Ceramic will be easier to cut than porcelain especially with a cutter aimed at the DIYer.
A good flexible cement based slow or standard setting adhesive would be best, avoid rapid setting you will possibly end up throwing more away than using.
You could use a premixed adhesive, but only on much smaller sized tiles and you would need to leave it to dry longer before grouting.
Again a good quality cement based flexible grout is essential, Screwfix sell Mapei products, or if you have a CTD or local tile supplies they should be able to recommend suitable products.
Any questions just ask, but take your time and enjoy it. :)
tfasb21
DIY Tiler
lu5 5ue
Many Thanks for your reply.
The boards were fixed by someone else. But I have checked and the round washers were used.
I will have a look for the tape and tanking > are there any recommended makes for these ?
Tile size of 600 x 300 I hadn't considered as I assumed they would be too big. The previous tiles were very old and were the small 20x20 square ones.
How can you determine if the tile is going to be too heavy ? I presume it depends on tile backer board as well as the adhesive used? So for my 10mm there would be a max limit on tile size I could use ?
Boggs
1,118
Uk
600 x 300 are now a very common size, some guys on here are fitting thin porcelain in 8 x 4 sheets.
Your backer boards will hold around 50-60kg sqm so really most tiles will be fine.
I will have a look for the tape and tanking > are there any recommended makes for these?
Unless a PU adhesive was used to join the board edges together, all board joints, transitions, and mechanical fixings will need tanking.
Basically anywhere where there’s a break in the surface of the board.
Obviously the board is waterproof, holes are not 😊
The simplest way would be to apply a butyl self adhesive tape over them. (Rubber based sticky tape) or youcan use a paint on type.
Paint on the tanking paste, apply an alkali resistant tape over it and apply a second coat of tanking.
(Possibly a cheaper option)
This is your type of board with a butyl tape applied, it’ll show you what is required.
Reply to Advice on tile size and materials. in the DIY Tiling Forum area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
tfasb21
DIY Tiler
lu5 5ue
What member type are you?
  1. DIY Wall and Floor Tiler
DIY Tiling Forum
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
