Discuss Advice on tiling onto "overlay" underfloor heating in the Canada Tile Advice area at TilersForums.com.
There are other overlay systems that are much safer to use Jon, Polypipe being one, or other similar types. These are installed in to inert gypsum or cement based boards and are far more suited to your application.
You may also consider Bekotec therm from schluter, it’s a very low profile ufh system fitted in just 35mm of screed (I think it’s 35mm) which can be run hot or cold. I must admit I don’t know off top of my head if it’s suitable with your heat source. But knowing schluter, I’d be surprised if it wasn’t.
Jonner
From the download i send of the Low Pro 10 it looks like it uses gypsum (or similar) boards for the straight sections and includes the curve detail for one of the ends and then you use the plastic castilation panels to make the other curve end.
Not sure if we need to put additional insulation down on the floor first?
Oh ok, a little odd, but ok.
So first thing to note, gypsum boards.
Gypsum and cement don’t mix well. Make sure the gypsum boards are well primed, not with pva! But an acrylic or an sbr based primer. Minimum 2 coats.
Pressurise system as suggested and leave at around 5-6 bar if possible. Latex over pipes regardless of what instructions say. It will eliminate voids beneath your tiles and afford a better transfer of heat to your tiles. You can use an anti fracture mat as opposed to a full decoupler. Few differences but in essence an anti fracture mat is only 1mm thick as opposed to 4-5 with a decoupler. Let any decoupler or anti fracture mat cure overnight. Do not tile it straight away as suggested. Then tile.
Do not use suggested adhesive unless a professional tiler is doing the job. You WILL throw away more than you use if you are doing the Tiling. It’s one of the most difficult adhesives out there
Jonner
Thanks again Marc
on page 5 they mention "schnellgrund" primer to seal the gypsum
I will look onto acrylic or sbr primers as i will be doing this bit once pipe is laid
As i am doing the tiling was thinking of going for de-coupler (belt and braces). Did not realise that the decouple had to be "bonded". I guess with a felxible tile adhesive?
Please could you suggest an adhesive that i might have some success with, as yes i am planning on tiling
Cheers Jon
Uheat - Jake
TF Official Sponsor
143
743
Very interesting thread...
The Hetta system is a popular one which many suppliers of UFH sell, however any type of EPS or XPS Polystyrene boards need a overboard before any form of tile can be applied to it. These systems are really suited for a Engineered Wood or Laminate. You can use a screed board over the top of it which is then fixed to the sub base however you have to be very careful of the pipes and where you're placing the screws.
These very reasons are why there's a new type of product on the market which is the Gypsum Retrofit panels which are a solid gypsum board which can accept a tile directly laid on top. The Gypsum boards have certainly become more popular recently due to not needing any extra materials. We supply a 18mm Version of this panel with pre-grooved pipe channels and end returns built in, suitable for a 12mm PERT Pipe. These boards can be primmed on the face and base before any adhesive or leveller is applied.
With our boards we state that the unused pipe channels need to be filled with compound before either a decoupling or tile is laid, this removes any voids that could be under the floor. I've attached a few photos from customers installations. If anyone needs any help on a system or installation, give me a call or send me a PM as we're happy to help everytime!
The polypipe system which has been around a while uses gypsum boards, and after a few years of publishing different installation techniques, they’ve finally produced a method statement in lines with what we want as fixers.
Which is to have a latex layer over the pipes of approx 5mm, then preference is a
decoupler/anti fracture mat, then tile.
The mat not being essential for porcelain but definitely with natural products and thin tile, but always preferred.
Although there are Tiler’s that will fix straight to the boards, there’s certainly another school of thought that feels that this is not the most effective method.
Also a lot of people miss the fact that they are gypsum and not cement!!
Therefore, priming correctly is essential, whether it be before latex or adhesive.
They are not a match made in heaven.
Uheat - Jake
TF Official Sponsor
143
743
A Flexible SLC is perfectly fine to go over our panels as well before a decoupler is applied and is also the easier method as it'll fill the unused pipe channels as well.
Jonner
Thanks again everyone. Your comments are making me feel more and more confident about the gypsum board based UFH that we are now looking at from Nu Heat called Lo Pro 10.
I will ensure that the gypsum boards are sealed/primed with SBR prior to install followed by de-coupler.
Marc - as yet no decisions re the tiles! Although it is an old cottage we are currently not thinking natural stone due to the need for sealing and maintenance. We are after something hard wearing, with a natural stone type texture/pattern (not polished smooth) in light tan/beige colour, oh and not expensive as we have about 60m2 to tile. So any recommendations on tiles and then adhesive would be great.
Reply to Advice on tiling onto "overlay" underfloor heating in the Canada Tile Advice area at TilersForums.com
🔥 Did you know that Polypipe Building Products Overlay Plus underfloor heating boards can be...
Tilers Talk BB
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
We had a water underfloor heating installed and tiled over. 3 months later we noticed many tiles...
Amethsyt
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
