Discuss Advice on tiling with 60cm x 30cm wall tiles in the British & UK Tiling Forum area at TilersForums.com.
L
Lianne
Can anyone please give me some advice on tiling with 60cm x 30cm wall tiles. I think the tiles are ceramic and approx 9mm thick. I also have a marble border.
I am revamping my shower room and really need some advice. I have tiled before but never with tiles of this size so need some expert advice.
The walls are not very good plaster - there are large patches where the old tiles pulled plaster off with them. So I am going to plasterboard the walls - I had considered stripping all plaster and attaching tiles directly to the breeze block but don't know if this is feasible. For the shower area I have purchased aquapanel board (but I couldn't afford to do the full room with this). I will be battening the walls and attaching 12.5mm plasterboard, from that point I am stuck, so any advice on the following will be really appreciated.
1. Do I need to do any further prep to the plasterboard?
2. Which adhesive should I use for this size tile? - I have heard that large tiles can sometimes have problems due to adhesive not setting in the centre!!
3. Should it be flexible? - I am assuming plasterboard may be subject to slight movement!!
4. Should the border be treated after installation due to porosity?
5. What is a really effective grout that is mould / fungal resistant?
Sorry to ask so many questions, but, I want to make sure I do this right. Many thanks for any advice you can provide.
Lianne
DHTiling
Hello lianne and welcome to the forums.......
You will need to get them walls as flat as you can with that format of tile.......
Adhesive wise i would use a single part flexible , BAL SPF is good...don't use dispersion adhesives on that size tile....
I would give the border a couple of coats of lithofin stainstop or similar...this will be better than trying to seal them once installed.
Aqua panel would be ideal for the shower area.....
And BAL and other makes manufactures make anti mould grouts.........
I would deffo dot & dab the walls with plaster board......much easier to tile onto than block work...
DS Tiling
Even although you are using Aquapanel the shower area should still be tanked out. All the plasterboard should be primed with an acrylic primer as a bagged adhesive should be used for this size of tile. You will have to use a trowel depth to ensure you are getting sufficient coverage and that will also depend on how flat the substrate ends up. Something like Bal single part flexible or equivalent would be fine for adhesive. Grout, something like microflex. Personally i would seal the border prior to installing especially if it is mosaic like. Lithofin stain stop or similar.
L
Lianne
Thanks for all your comments. I didn't realise I still needed to tank the shower walls, better buy a tanking kit - is the Dunlop Waterproof Tanking kit suitable?
Dave>> great comments/advice, just one query: is 'dot and dab' suitable? I read somewhere plaster can only hold a certain amount of weight (approx 20kg I think) , so wouldn't I be overloading the existing plaster by adding the weight of the plasterboard, adhesive and tiles. I may be talking non-sense, but just want to make sure. The advice about lecithin on the border prior to fiixing will certainly be a great help.
DSTiling>> great comments/advice. Again the border prep prior to fixing is invaluable.
Mick the Tiler>> Don't know where they originate from. But they are not a white glazed tile, they are a marble effect ceramic, with a high gloss glaze - the tile store assured me they were suitable for installation in a shower, so they had better be OK.
Thanks again for all your help.
Lianne
GazTech
Lianne
Preperation Products
Shower Waterproofing Kit
• Waterproofing Kit For Showers
• Fully Waterproof And Leak Proof
• Quick And Easy System
The Ideal Waterproofing System For Showers
Download Material Safety Data Sheet
Click here to view video
easy to use kit is fine .Gaz
Droopy
Even with aquapenel there are still joints need taping, and where the tray meets them...Gaz
So why not save the money that aquapanel costs and do it all in Greenboard?
Either that or tape using a glass fibre tape and a water resistant SPF addy.
Reply to Advice on tiling with 60cm x 30cm wall tiles in the British & UK Tiling Forum area at TilersForums.com
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
Hi am re tiling kitchen and want some ideas as to what’s best to repair the walls after Remiving...
Help please from any tilers. The plumbers made a mistake and had to rerun pipes after...
Hi all am changing tiles in my kitchen ans expect to damage the walls removing tiles . Think the...
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
