Discuss advice please in the British & UK Tiling Forum area at TilersForums.com.
I
Iain79
Hi,
I have underfloor heating which i belive is water running through pipes but powerwed but eletric as we have no gas in the village. In the bathroom the pipes are under concrete floor by about 2mm i think or 2 cms not sure. I Planned to get the bathroom tiled. can i pick any tiles or have i gotta pick somthing special. I know i gotta get some special expandble grout. Thanks for you help peeps.
Iain:mad2:
Daz
If you are employing the services of a professional tiler, you will find that we prefer to supply adhesive and grout so that we can be sure of the performance and finish of the products.
Explain all that you know about your substrate and the tiler will be able to recommend the correct materials to be used for fixing and grouting.
As far as the tiles go, I usually advise clients that they can select whatever tiles they like. However, there may be additional preparation required if they select a natural stone, for example.
nybor62
1,083
rotherham
ok thanks lads... im getting a pro to do this but also he he said it not worth the hassle to lift the toilets and sink up as sum off the pipes will need excended... so he said he will cut round the toliets and sink. How good and clean can the a pro cut rounds a shape like this.
should,nt be a problem if he says thats what he wants to do then im sure he can do it . i would prefare the it out but if its going two cause a problem . i would,nt have a problem cutting round them. what do you want your the customer
I
Iain79
well want him to cut round it as he said will cost less and if i keep a few tiles and it comes to putting new toliets and sink in then the old one can come out and lay the spare tiles i kept. Just wonder if a tiler can do a neat job cutting round shaps??? as there bound to be a few rough edges, thou i have a feeling that you guys would put white silcon round it that i be happy with.
Reply to advice please in the British & UK Tiling Forum area at TilersForums.com
Had new bathroom by a builder who has subsequently gone bust and after 6 months the floor has...
Hi Everyone. I'm after some advice with regard large format Tiles with water fed underfloor...
Tiberiu Curelaru
advice please
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
