Discuss Advice pls: Floor has already had PVA!! in the British & UK Tiling Forum area at TilersForums.com.
N
natalleyem
Hi I'm looking for advice as to what to do next:
SITUATION:
Ensuite shower-room with shower tray.
Whole room to be tiled.
One wall leading into and inside of shower enclosure with Mosiacs.
Other wall inside shower enclosure large format tiles.
Rest of walls and floor large format tiles.
All tiles are metallic in design/colour.
Mosiac wall is mix of plastered plasterboard and bare ply - All joints/holes filled.
Floor is floor boarding sheets.
One wall plastered plasterboard
One wall (trowel finished) cement
Husband already started to PVA part of Mosiac wall onto plaster but I stopped him after reading this forum. The area he has PVA will not get wet but is to be tiled. He has also put PVA on the floorboarding sheets.
We are planning to use Unibond Ready Mixed Waterproof Wall Tile Adhesive -Extra Strong (Green/Yellow tub) and will probably purchase a similar ready mix floor tile adhesive product. Would rather use ready mix as DIY'ers.
We need to use a grey drying adhesive as any grouting product will be coloured dark grey.
Am now worried about PVA 'wet reaction' with Adhesive so Questions:
Should we/Do we need to rub PVA down?
What should we/do we need to prime/waterproof these surfaces with instead?
Have also applied PVA to concrete screed floor over underfloor heating which is soon to be tiled is this a big problem?
Your advice and suggestions would be very much appreciated before we go any further.
Thanking you in anticipation.
N
natalleyem
thanks for your advice Mikethetile - couple of further qu's if I may?
can you recommend a ready mixed mosiac adhesive that dries grey please?
and a cement based wall tile adhesive?
which adhesive do you recommend for for the floorboarding sheets?
and also for concrete screed floor?
would really prefer to use ready mix if possible!
thanks again
natalleyem
mikethetile
you really cant use tubbed for this job
its the way it dries thats the problem, tubbed dries by water dispersion into the substrate and the tile, the tiles you are using will not absorb enough to bond
you need a cement based addy as it dries by chemical reaction
have you already laid the backerboards to the floor
N
natalleyem
okay will avoid the tubbed - thanks
not using backerboards.
Builders have laid composite floorboarding sheets across expanse of bedroom including ensuite bathroom area. Am therefore assuming that it would be best to seal boarding to the bathroom area. Shower tray has already been fitted on top of boarding and waste is fixed in place. All ceilings below boxed in and plastered.
buddha1964
Are the floorboard sheets wood ?
Reply to Advice pls: Floor has already had PVA!! in the British & UK Tiling Forum area at TilersForums.com
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
